Watch of Today
mk3
Wearing a simple Sandoz today, basic day only powered by an ETA2824. I got this cheap off the bay for less than the price of a new balance wheel and figured I'd use it for parts but its been running well and it seems a shame to break it down. It has its original crown and bracelet which tapers to a tiny 12MMS at the clasp.
I haven't done anything to it and it's been keeping time accurately for the last 3-4 years. Only issue is the movement is a bit loose in the case but I have a cunning dodge to fix this.
It's interesting in the sense that you can see a lot of Rolex in the basic design, even the tapering bracelet is kind of a Rolex thing. I believe this was cased in Hong Kong or made for the HK market where Rolex are popular...a wannabe so to speak.
Original crown
Signed bracelet..
Have a nice day!
Anilv
Got my Huntana on today
It's been getting quite a lot of wrist time lately. At 34mm diameter and just 8mm thick it is just such a comfortable watch. The thin bezel makes it wear bigger than it is and the design and layout is so easy to read.
It has a Unitas 6325 inside which is a lovely movement. A nice easy size to work on, simple, bullet proof, consistent, and reliable.
This particular one is also the loudest ticker I have.
@Cad101 that's a very nice Helvetia indeed. I love that huge sub-dial and as you say, the movement is very obviously UT 63xx based, albeit with a slightly different jewel configuration to my 6325.
Edited by Marc
capitalisation
10 hours ago, ricardopalamino said:
Today I'm going with a vintage Seiko Sportsman Seahorse I haven't worn for a while ..
louis - you don't see too many of them (seiko) in that combo - stainless case and gold finished dial. i love that look.
i am totally unfamiliar with a huntana, but i love it!! very sweet looking. that is a perfect dress watch.
if you ever felt the need to part with it, look here first. it's a beauty.
6 hours ago, Cad101 said:
Well @Marc I've had something similar on for the past week. The movements are very similar I know the H65 and H66 were the Unitas 6310 but the H64 is very similar indeed.20170215_194937.thumb.jpg.e762461c27016b0cdd4392badc0be393.jpg20170215_195633.thumb.jpg.0bad32a658dba5ec6c4b6cbc4bdb5396.jpg
every helvetia i've seen has been a great looking watch. this is no exception. that is very nice.
Been wearing this for the last 18 hours since I finally adjusted the donor hairspring into some kind of shape its lost about a minute in those 18 hours. I will get it back on the timergraph I may be able to tweak it a bit more.20170219_154543.thumb.jpg.1acdcea47a6641abe40a66ed991e9fdc.jpg
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
