Watch of Today
mk3
Wearing a simple Sandoz today, basic day only powered by an ETA2824. I got this cheap off the bay for less than the price of a new balance wheel and figured I'd use it for parts but its been running well and it seems a shame to break it down. It has its original crown and bracelet which tapers to a tiny 12MMS at the clasp.
I haven't done anything to it and it's been keeping time accurately for the last 3-4 years. Only issue is the movement is a bit loose in the case but I have a cunning dodge to fix this.
It's interesting in the sense that you can see a lot of Rolex in the basic design, even the tapering bracelet is kind of a Rolex thing. I believe this was cased in Hong Kong or made for the HK market where Rolex are popular...a wannabe so to speak.
Original crown
Signed bracelet..
Have a nice day!
Anilv
Got my Huntana on today
It's been getting quite a lot of wrist time lately. At 34mm diameter and just 8mm thick it is just such a comfortable watch. The thin bezel makes it wear bigger than it is and the design and layout is so easy to read.
It has a Unitas 6325 inside which is a lovely movement. A nice easy size to work on, simple, bullet proof, consistent, and reliable.
This particular one is also the loudest ticker I have.
@Cad101 that's a very nice Helvetia indeed. I love that huge sub-dial and as you say, the movement is very obviously UT 63xx based, albeit with a slightly different jewel configuration to my 6325.
Edited by Marc
capitalisation
10 hours ago, ricardopalamino said:
Today I'm going with a vintage Seiko Sportsman Seahorse I haven't worn for a while ..
louis - you don't see too many of them (seiko) in that combo - stainless case and gold finished dial. i love that look.
i am totally unfamiliar with a huntana, but i love it!! very sweet looking. that is a perfect dress watch.
if you ever felt the need to part with it, look here first. it's a beauty.
6 hours ago, Cad101 said:
Well @Marc I've had something similar on for the past week. The movements are very similar I know the H65 and H66 were the Unitas 6310 but the H64 is very similar indeed.20170215_194937.thumb.jpg.e762461c27016b0cdd4392badc0be393.jpg20170215_195633.thumb.jpg.0bad32a658dba5ec6c4b6cbc4bdb5396.jpg
every helvetia i've seen has been a great looking watch. this is no exception. that is very nice.
Been wearing this for the last 18 hours since I finally adjusted the donor hairspring into some kind of shape its lost about a minute in those 18 hours. I will get it back on the timergraph I may be able to tweak it a bit more.20170219_154543.thumb.jpg.1acdcea47a6641abe40a66ed991e9fdc.jpg
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
