Zeitner watch Links
I share your pain, I was stuck this summer with this problem for a 90's Head Titanium, a very rare bird that I really like, don't try to find one I never found any specs or who made it.
The band was just a bit small, I spent days looking online for something compatible, never found anything.
Then I discovered buckle extenders, it worked for me.
There are 2 types for Stainless Steel: fixed and spring loaded versions:
http://www.esslinger.com/watch-band-part-stepped-buckle-extenders/
http://www.esslinger.com/watch-band-part-spring-loaded-buckle-extenders/
http://blog.esslinger.com/how-to-install-a-spring-loaded-buckle-extender/?_ga=1.264276491.588626422.1465156968
I went with the spring loaded, best decision I ever made, very easy to install.
Hope this helps
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
