Beautiful Waltham Pocket Watch
I found some info. If the movement serial number matches the case, then this watch is a 15 jewel adjusted movement. Usually the numbers don't match because cases were sold separately from movements, but someone else may correct me if I am wrong on this.
 Can you open and show picture of the actual movement to confirm?
Movement Serial Number: 577173
Grade: A.T. & Co.
Model: 1857
Estimated Production Date: March 1873 - May 1873
Run Quantity: 760
Total Production: 69,248
Jewels: 15j
No correction needed, cases were mass produced by several different co's, that it's real common to find one branded watch in different case, often there were re-cased after original plum wore out!
That is one BEAUTIFUL dial! Well used watch, can you get movement pic?
Correction is needed, on myself,:huh: case and movement numbers rarely match,  Original Noirrac1 assessment was on case number, (this is what happens if you don't read post and it's very early in am!!) if it matches movement, then it is spot on, really need to see movement s/n....thanks!
As far as I know "Walthams" were movement manufacturers. It's highly unlikely the serial number will match the case unless made to special order, which I've never heard of.
I suppose a case manufacturer could produce a case with matching number, why I can't imagine.
Numbers on movements or even cases are more to do with "Accounting Purposes" than production dates, though granted, many run in sequence.
It's entirely possible that a manufacturer could use separate Accounting number's for different models.
Why do manufacturers even use serial numbers ? It's normally more to do with submitting some type of information to the relevant authority with regards to income tax returns.
Sent from my SM-T585 using Tapatalk
5 minutes ago, digginstony said:
Forgot to say. If the watch is size 18 it could be "Special " when I first looked I thought it to be a smaller ladies watch. Very interesting now
Exactly. I thought it was a smaller watch too.
Joe
Great info. I know very little about pocket watches. Any idea how much a piece like this is worth? I haven't really been able to find anything to compare it to.
If own about a dozen "Walthams " but nothing to compare with yours. The movement is of high quality but there are movements more sort after to the collector, such as the 23 jewel "Vanguard" and the 17 jewel "PS Bartlett" etc.
I'm no expert in anyway and don't pretend to be. I haven't collected for a long time but as to valuation, it's worth what somebody is prepared to pay for it. To me, the watch is unusual with particular reference to the dial and watch size but would of been far more interesting if it were 18 size.
Hopefully there are more knowledgeable guys on the forum that can assist. It's probably worth having it professionally looked at and valued.
Not to avoid the issue of value totally. I would guess the value to be £200 to £350 but a professional, cognizant of the present market place would be able to help much more.
I did quick look on the bay for similar sold watch, prices vary greatly, overall condition is most important, the case is worn with brassing, dial is cracked, (but still beautiful) and you didn't mention if watch is working, also important in terms of value, add in number of movements mfg. (scarcity). On the good side the movement is beautifully damaskseened and the regulator looks to be pretty unique, Original pricing is on about page 16 in this link
https://books.google.com/books?id=8fQ3AAAAMAAJ&printsec=frontcover&dq="The+Perfected+American+Watch"&hl=en&ei=yxLwTIrtI4OB8gaY4K3DDA&sa=X&oi=book_result&ct=result#v=onepage&q&f=false
I'm not an expert but in current condition ~$75-$100 USD, that's based on sold similar watches and of course condition. You can search NAWCC website for more info. They won't discuss value on this site, FYI
Hope that helps.
Dave
Get somebody to look at the watch. Preferably an Auctioneer. Don't recommend Ebay. Would say I've seen worn out basic Walthams sell on bay for the price WileyDave quoted.
I made the assumption the watch is working ?
If your friend is thinking of selling, a specialist auction would be a better place. If your friend is offered or only reaches $75 to $100. Tell your friend to KEEP IT !
My impression is that people will buy any old rubbish on the bay upto about £70. Then it becomes harder. But what do I know[emoji4]
I've just looked on ebay and found something similar. It's obviously a ladies watch. With diamond in centre of the case. Which is probably only a diamond chip of little value ? The case is gold plated.
The seller is asking £385. Doesn't mean he will get that price though !
Right you are digginstony, I used the bay as gauge for similar watches or how much I should pay for a particular watch, by no means does this make it a "worth" this much :), I've always gone by worth, as how much someone is willing to pay for it! Most, (not all) sellers when it comes to pwatches inflate their prices, because they don't want to take the time to research or they really believe someone will pay asking price
Hoping Dave C member will chime in, I know he has more experience in these.
Right you are digginstony, I used the bay as gauge for similar watches or how much I should pay for a particular watch, by no means does this make it a "worth" this much [emoji4], I've always gone by worth, as how much someone is willing to pay for it! Most, (not all) sellers when it comes to pwatches inflate their prices, because they don't want to take the time to research or they really believe someone will pay asking price
I've never been successful at gauging prices! They vary so much at auction.
I've seen an empty size 16 case sell on the bay for £100 ! Then an identical case sell a few weeks later for £30.
Collectors may love this watch or think it feminine and for its size hate it. Who knows I don't.
When I was collecting I had a figure in mind and wouldn't be tempted to go above it.
As to the condition and being original. This would take close inspection and even then would only be a point of view, due to the nature of the trade.
It could of been re-cased or the dial added later from an earlier watch.
That's what I do, keeps me out of trying to get something for less than it's really worth. But by doing the legwork and researching production numbers and what they've sold for, I can get better idea how much to pay. Because of the volume of American watch companies produced, there are tons of movements that just aren't worth the effort to collect, sure they are good to fiddle with and repair, but there were so many produced just not that valuable. (obviously higher jeweled watches >17 are more desirable and command higher prices) Unless you can really be sure that hands, dial, case and movement are all original, (to the watch), then it's a guesstimate at best.:biggrin:
It's a tough thing to gauge from US to Euro/UK.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
