hello from up North
Yorkie
Hello all,
Got bitten by the watch repair bug only very recently, so essentially a complete beginner.
reading the books, collecting the tools and playing with some basic movements.
will be using this site extensively , me thinks.
Quick question - where would i find a document/book/website describing all possible watch models and makes, so i can start to recognise watch types better?
(I dont mean the tech sheets as i have founf those, thanks)
Many thanks
Many thanks
Greetings and Salutations!
Well, all possible models is a tall order, there have been an astounding number and variation of watches produced over the years. You might take a look at the book section at Cousinsuk.com, the Wristwatch Annual would give you an overview of modern watches, and some of the collector guides might help with older ones.
Have fun!
Hi Yorkie, I'm new here, too.  You can learn a lot from the bestfit catalog.  It shows a lot of movement brands and even has some pictures of various parts.  It won't help you with history or prices or collectibility (I know that's not a real word), but it  is sure helpful if you're looking for parts.
  • 4 weeks later...
Hello Yorkie,
I would suggest you get the Complete price guide to Watches by Cooksey Shugart as it is the nearest you will get to what you are asking for.  It contains a load more than just prices including pics of movements and parts for recognition, I get a new one every couple of years.
It has of course not got every make of watch documented but it is a thick book with loads of info. Tracing on the forums for specifics will give you a good chance of a result as much has been documented.
Cheers,
Vic
Edited by Vich
Welcome and Vich is right, even a ten year old Shugart book has enough basic info to get you more than excited about watches and what to look for, sadly they don't cover Japanese models (or at least the one I have) and most of the "American" manufactures, Hamilton, Bulova, Waltham all had Swiss made movements through the years, so good luck and don't be afraid to ask questions.
well chaps , you were all right. The watch bug got hold....
been reading the forums, got books for xmas, including the cooksey book, purchased 2 broken pocket watches and fixed them, acquiring tools now, this site is superb for learning/training - thank you Mark
recently met a local 50yr + experienced watch repairman which is invaluable.
Frightened now the watch collection starts....
Also have the Watch repair virus :) 36 Pocket Watches fixed so far and not one sold:)
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
