Snailing pattern decoration
szbalogh
My next project is to prepare another spindle to be able to make snailing pattern on movement plates and wheels. I will try to replicate Steffen Pahlows demonstration.
https://www.youtube.com/watch?v=S_S8oA9HdlY
Currently i have one ER20 collet spindle driven by a regulated car fan DC motor that is exellent for turning parts in wax collets. My plan is to prepare another of such DC motor for the other spindle.
Here is a picture with the DC motor disassembled and ready for cleaning. You can notice that i have already cleaned the commutator.
Next is to turn a grinding attachment with a cylindrical grinding face mounted on the shaft of the second motor with set screw(s).
At about 5 minutes and 50 seconds into the video below they show finishing the plates then how the girl puts decoration on and even one of the templates they used.
https://www.youtube.com/watch?v=ys4ChOWYNy8
In the next links they show a variety of techniques and you learn some new terminology like GENEVA WAVES (COTES DE GENEVE) and CIRCULAR GRAINING (PERLAGE)
http://www.thehourlounge.com/en/vacheron-constantin-articles/movement-finish-true-mark-haute-horlogerie-557275
http://www.watchwow.com/2013/09/110008/basics-of-movement-finishing?page=2#.V9hSrIJ0-70
Then a different technique which unfortunately uses a really expensive machine but does produce interesting results. Plus from time to time she runs classes with the machines she has.
https://mechanicalcurios.com/2016/02/15/photos-from-engine-turning-ii-class/
First try on a simple washer. It was not flat so flattened a bit on a whetstone, hence the radial scratches.
I was using chromium powder (Cr2O3) in oil. It has some fine grain. The snailing pattern is definately there but i need more coar.se paste and need to try grinder with different diameters and speeds.
Edited by szbalogh
Once again Szbalogh I am awestruck by your ability to achieve amazing results using the most basic of set ups.
Innovation, imagination, and a "can do" approach winning over expensive kit once again, you are an inspiration.
Thanks for the video.:thumbsu::bow::bow::thumbsu:
Szbalogh, I think with the correct speed and course grit you are going to get the correct finish.  I really enjoy watching your approach to things, you remind me of my father, who virtually never got stuck on any job due to his innovative ways. Keep up the good work!
Winding wheel on the wax chuck after grinding the pattern. It has the paste on it, but here one can clearly see the lines grinded in the material.
Washed with paint solvent:
Here is the retaining washer after finished grinding:
And in the movement with a blued screw :)
From a distance:
Tomorrow i will make a two stage pattern on the  ratchet wheel.
Looking good eh? :)
But lets take a closer look! Notice the part close to the middle was not grinded. I was not grinding long/deep enough. The grinder did not touch this part of the wheel. I missed this before started grinding the external circle.
I could start the grinding again but it will do in this watch, since the wheel is mounted with a plate hiding that part.
  • 2 months later...
Szbalogh,
Do you live in a part of the world where you are surrounded by watchmakers? You have a clear picture in your mind of what you want done to the watch and then work out the procedure to achieve that goal. Your degree of focus and innovation has to come from somewhere. The work itself is amazing but watching the machinery you are using moves it up to extraordinary.
david
  • 4 months later...
Добрый день. подскажите пожалуйста, какую пасту вы используете,и делаете ли наклон , для получения рисунка
Good afternoon.  Tell me which pasta you use, and whether you are tilting to get  Drawing
Я использую алмазную пасту из Китая. Это 1-2 USD / 10gram. Долговечность. Да, я наклоняю две оси.
I use diamond paste from China.  This is 1-2 USD / 10gram.  Durability.  Yes, I cant two axles.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
