Snailing pattern decoration
szbalogh
My next project is to prepare another spindle to be able to make snailing pattern on movement plates and wheels. I will try to replicate Steffen Pahlows demonstration.
https://www.youtube.com/watch?v=S_S8oA9HdlY
Currently i have one ER20 collet spindle driven by a regulated car fan DC motor that is exellent for turning parts in wax collets. My plan is to prepare another of such DC motor for the other spindle.
Here is a picture with the DC motor disassembled and ready for cleaning. You can notice that i have already cleaned the commutator.
Next is to turn a grinding attachment with a cylindrical grinding face mounted on the shaft of the second motor with set screw(s).
At about 5 minutes and 50 seconds into the video below they show finishing the plates then how the girl puts decoration on and even one of the templates they used.
https://www.youtube.com/watch?v=ys4ChOWYNy8
In the next links they show a variety of techniques and you learn some new terminology like GENEVA WAVES (COTES DE GENEVE) and CIRCULAR GRAINING (PERLAGE)
http://www.thehourlounge.com/en/vacheron-constantin-articles/movement-finish-true-mark-haute-horlogerie-557275
http://www.watchwow.com/2013/09/110008/basics-of-movement-finishing?page=2#.V9hSrIJ0-70
Then a different technique which unfortunately uses a really expensive machine but does produce interesting results. Plus from time to time she runs classes with the machines she has.
https://mechanicalcurios.com/2016/02/15/photos-from-engine-turning-ii-class/
First try on a simple washer. It was not flat so flattened a bit on a whetstone, hence the radial scratches.
I was using chromium powder (Cr2O3) in oil. It has some fine grain. The snailing pattern is definately there but i need more coar.se paste and need to try grinder with different diameters and speeds.
Edited by szbalogh
Once again Szbalogh I am awestruck by your ability to achieve amazing results using the most basic of set ups.
Innovation, imagination, and a "can do" approach winning over expensive kit once again, you are an inspiration.
Thanks for the video.:thumbsu::bow::bow::thumbsu:
Szbalogh, I think with the correct speed and course grit you are going to get the correct finish.  I really enjoy watching your approach to things, you remind me of my father, who virtually never got stuck on any job due to his innovative ways. Keep up the good work!
Winding wheel on the wax chuck after grinding the pattern. It has the paste on it, but here one can clearly see the lines grinded in the material.
Washed with paint solvent:
Here is the retaining washer after finished grinding:
And in the movement with a blued screw :)
From a distance:
Tomorrow i will make a two stage pattern on the  ratchet wheel.
Looking good eh? :)
But lets take a closer look! Notice the part close to the middle was not grinded. I was not grinding long/deep enough. The grinder did not touch this part of the wheel. I missed this before started grinding the external circle.
I could start the grinding again but it will do in this watch, since the wheel is mounted with a plate hiding that part.
  • 2 months later...
Szbalogh,
Do you live in a part of the world where you are surrounded by watchmakers? You have a clear picture in your mind of what you want done to the watch and then work out the procedure to achieve that goal. Your degree of focus and innovation has to come from somewhere. The work itself is amazing but watching the machinery you are using moves it up to extraordinary.
david
  • 4 months later...
Добрый день. подскажите пожалуйста, какую пасту вы используете,и делаете ли наклон , для получения рисунка
Good afternoon.  Tell me which pasta you use, and whether you are tilting to get  Drawing
Я использую алмазную пасту из Китая. Это 1-2 USD / 10gram. Долговечность. Да, я наклоняю две оси.
I use diamond paste from China.  This is 1-2 USD / 10gram.  Durability.  Yes, I cant two axles.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
