Identification please.
Blacklab
This has just been passed to me for restoration:
Quite acceptable on the outside, strikes but does not run, pendulum missing (may turn up soon), movement very dirty & not signed:
20160530_101706r.jpg20160530_101746r.jpg20160530_101756r.jpg20160530_101812r.jpg20160530_101722r.jpg
Shows serial number 169240 with 18 above on the back plate, 20 on the front plate. Apart from the grime everything seems to be in good order. Any information about the movement (age, maker etc.) would be gratefully received. Also pendulum info would be useful (if the original turns out to have disappeared for good).
Something tells me this is German, I don't know it's just a gut felling. If it isn't German then it would be English.
The case is an architectural form with what looks like a silvered dial with roman numerals with spade style blued hands and what looks to be a mahogany or mahogany type case going by the one and only case picture.
The movement is a 8 day Westminster chime with half hour and hour strike and spring driven. It has a regulator hand blued on the dial above the 12. It strikes on gongs. It looks like an anchor escapement.
Here is a picture of what I think the pendulum should look like. You are lucky to have the original suspension spring as this can be used as a guide to the length of the pendulum rod, but the weight you can only guess, It would be quite heavy. The numbers you have quoted to me doesn't help me in any way sorry.
Thanks for the info OH. Likewise I think its German & may have had a makers name plate screwed above the serial number:
I would suspect that this may have been removed after WW1 due to the anti German attitude at the time, ultimately causing German clocks & other imported goods being labelled 'Foreign'. A quick search for pictures of German bracket clock movements shows similar clocks & movements with missing name plates.
The movement is now stripped awaiting cleaning & I did manage to get it running beforehand. Initial inspection shows no undue wear to the pivots or bushes & no broken or missing parts, so (hopefully) it should be a simple clean & oil. Undecided at the moment whether to re-silver the dial:
I would leave the dial to me its still in good condition. I would go along with that sort of period about the early 1920's.
Here is a good one for you I'm very much into my family tree and on my late Mothers side I found a Bismarck Hambling born 1896, I bet he was popular in the times of WW 1.:D
Edited by oldhippy
  • 7 months later...
After a rather long pause I finally got round to putting it all back together again. I do respect your advice O.H. but in the end I did re silver the dial & frame:
The movement was dipped in Priory clock cleaner & polished as reqd. Reassembly went without any major incident:
Hands cleaned & re blued, new leather pads fitted to strikers, case cleaned with Priory polish reviver.
Before & after:
20160522_231553r.jpg20170121_202225r.jpg20160522_231229r.jpg20170121_202526 r.jpg
Apart from cleaning off the crud on the gongs these were left as is, along with the side & back fabric & mesh grills. Going like a train, gongs & bongs all happy. All in all an enjoyable one, but I am still waiting for the pendulum (which has been found apparently) & none the wiser to identification.
    • In repairing a generic Swiss cylinder quarter repeater pocket watch with no repeat mainspring I'm trying to work out how to determine the size of a suitable spring.  Barrel ID 7.6mm, Arbor 2.77mm height around 1.45mm. Clearly only one turn is used plus setup, but the only actual figure I can find in Saunier who says in the previous half century 3.5 turns was considered good (and Saunier is about 1880).  Calculating off that would suggest about a 0.15mm thick spring 128mm long. That feels intuitively a little thick, but I don't have another repeater conveniently to hand to check so any pointers welcome.  Photo shows the repeat train assembled without the bridge since that hides everything.   Alan
    • To identify movements the standard practice is the actual diameter of the movement, and a front on image of both the movement side and the dial side- minus the dial. The setting mechanism (under the dial) is considered the "fingerprint" of the movement and 9/10 leads to full identification.
    • What of? The wheel itself (standard lever escapement) or the plate with no numbers on it? Does that help, from the ebay listing?
    • Thanks. I did make a self introduction— perhaps in the wrong place? 🤔😢In any I am an Australian 🇦🇺 American living in the beautiful Gold Coast, Queensland Australia. I love Grand Seiko and Seiko watches, and recently came back from the Grand Seiko Shizukuishi Studio in northern Japan where I was blown away by the design artistry and technical excellence. More later on that (including photos, if interested!)
    • Bbefixer. I had the same type of problem when I first joined the forum. A pocket watch movement with no markings. Photographs of the the movement, and the members came to the rescue. Within days I had a number of suggestions. Found the details and information of the movement on ranfft. Never managed to get a donor, but at least I know what I need.  The members are really knowledgeable.
