Seiko 7619...
  A friend of mine that sells goods at the swap meet told me that he had 3 watches that weren't working and asked me to take a look .
They were a Seiko Kinetic , a Citizen Eco-Drive , and this Seiko 5 Sportsmatic Deluxe 25 jewel automatic from March 1966 .
The Kinetic and Eco-drive were power problems but the automatic was stuck , ...the balance would swing when the watch was shaken but no movement from the drive train . There is a regular crown for setting and a push button that I didn't know the purpose of . Both the crown/stem and push button were rusted stuck . I found out that this model has a hacking feature that stopped the center wheel via the crown/stem and because the crown was in the setting position , the hack was engaged  holding the gear train in position although  the balance was free .  The push button changed the date wheel when pushed....if it wasn't rusted .
  I also found out that I could not get the tech manual for this caliber , but a member from another forum sent me the tech Info from a  Caliber 7606....which is close but not the same .
  I told my friend that I would fix the Kinetic and Eco-Drive at my cost if I could keep the automatic and he had no problem agreeing to this arrangement .  I installed a new capacitor in the Kinetic and it was happy , and I left the Eco-drive in a sunny place for more than 16 hours ...and it was happy .
I removed the movement from the automatic and and let the parts sit in a bicarbonate of soda and water solution for a couple of days alternating with a spa treatment in the ultra-sonic to take care of the rust problem . The small cir-clip on the pusher was toast , and after searching for one on the Bay with no luck , I was able to rob one from a Seiko 7T32 chrono that's now a donor .
  A service on the movement and a very light buff of the case and bezel , a light polish of the case , bezel , case back and crystal and now this puppy's Happy .    :thumbsu:
Oh that's a nice piece, well worth the effort.
I've been working on some scrap Seiko movements for practice lately, and it's deepened my love for the brand, made well, with a design that's really nice to work on, specifically the click springs and calendar jump springs, really watchmaker friendly, they don't fly off to the moon if you're not careful.
Edited by Ishima
Nice work, what's the translation of the writing on the caseback?
I have a slightly older sibling, a 7619-7010 from September 1965 (with the obligatory rattly rotor):
Sorry didn't notice your request on the other site or I could have sent you this:
Seiko 7619A.pdf
bit late in the day & its only the parts list.
Edited by Blacklab
attachicon.gifSeiko 7619A.pdf
Thank You for the PDF Blacklab.It's hard to get tech info on this caliber it seems ... I don't know what the inscription on the back is yet  . I often talk to a seller at the swap meet that's originally from Japan and I can ask her next week .
Hi Ishima , heres a Seiko site to check out .
  • 2 months later...
Aloha blacklab , Sorry It took so Long to answer your question on the inscription . The Japanese Lady at the swap meet translated as best as she could . She had trouble describing Japanese words into English .
  Baisically it was a presentation watch to an employee of a Japanese railroad company. I will see if I can get a more definitive answer from someone . I'm working on a project at the Ilikai Hotel in Waikiki and there are lots of shops that cater to Japanese tourists .
  • 1 year later...
7619A.pdf
1 hour ago, Monk said:
Good evening,
I have just acquired one 7619-7010 and I am in search of information about the movement. The PDF file does not seem any more available, would have you a copy.
PS: sorry for me english, i'm French
Aloha Monk  ,
Here is what was in the PDF file . It's just a parts list . It says that the basic caliber is the 7625A .
Sorry I don't have any more info .  As I take the watch apart I take plenty of pictures and I use an ice cube tray to put the separate parts in with their respective screws so I don't mix them up .
I've attached some Seiko tech sheets for your reference .
http://www.thewatchsite.com/14-user-manual-technical-manual-casing-guide-downloads/15-seiko-calibers-technical-repair-manuals.html
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
    • Typically for introductions all you would have to say is hi I am interested in repairing watches and nobody's going to care about the technical details. Then to certain degree the introductions are not life or death in some cases I guess it depends upon what you did when you came to the discussion group. It's good that you're getting a balance complete for variety of reasons and getting a bonus balance bridge. Because I want you to pay attention to something when you get it as your hairspring still has a problem quite an amusing problem in a way. You notice your hairspring stud is a triangle or shape and it fits into a triangular shaped hole. It also notice how your hairspring has some weird bending right around the stud? So when you get your new balance bridge and the balance complete if you look carefully you'll find that I'm pretty sure the stud will be rotated and that they hairspring will come out the end not the way it's coming here you have managed to twist the stud putting it into the hole and that's why it looks so bad in the previous image. If you are skilled at fixing hairsprings which are not you can fix this. On the other hand are getting replacement so that's good. No it's supposed to be straight up and down. So in addition to twisting the stud you also bent it. On the other hand this is the most common place where people like to bend their hairspring and yes if you had practice with bending hairsprings this is all relatively sort of easy to fix. But I would really suggest practicing on another watch or basically scrap of balance wheels off of eBay that nobody cares about. Because practicing on something you care about really isn't the best. Then the reason I wanted the image below was to see how the balance jewel assembly is attached to the bridge. Sometimes it needed jeweling tool to push it out but in this particular case all you have to do is remove the U-shaped clip in the whole thing falls apart. But if you're lucky here replacement balance bridge will solve the problem.
